jamie_1992
What Manifold Is This?
jamie_1992
this manifold came with a gti6 engine i brought it was advertised as a 205 conversion
at a glance i thought it was a stranded gti6 manifold but when it came to fitting i relised the flange was different and im not really sure what car it came off
dose anybody know?
phase2 xsara vts.
Your been Ebayed I'm afraid, it as said above a standard Phase 2 VTS manifold which are pretty much worthless due to the connection
stu8v
I would'nt say its hard to get around though..
I also like the clamp arangement too.
you can use it easily enough, but you do need to be able to weld or know a decent welder/fabricator.
caballino
This is stock manifold?
It is the standard fitment exhaust manifold found on 2001 onwards (so called Phase 2) Citroen Xsara VTS models.
