jamie_1992
What Manifold Is This?
jamie_1992
this manifold came with a gti6 engine i brought it was advertised as a 205 conversion
at a glance i thought it was a stranded gti6 manifold but when it came to fitting i relised the flange was different and im not really sure what car it came off
dose anybody know?
phase2 xsara vts.
stu8v
As above, its what I've got fitted to mine.
Your been Ebayed I'm afraid, it as said above a standard Phase 2 VTS manifold which are pretty much worthless due to the connection
stu8v
I would'nt say its hard to get around though..
I also like the clamp arangement too.
you can use it easily enough, but you do need to be able to weld or know a decent welder/fabricator.
caballino
This is stock manifold?
It is the standard fitment exhaust manifold found on 2001 onwards (so called Phase 2) Citroen Xsara VTS models.
