stef205
[car_upgrade] Stef's 205 Gti6 Conversion And Tidy
both hubs 205 ones?
damo
Thanks dan,
Yes it often puzzles people, ive had a few people stop me and say something like "your cambelt or aux belt is to tight" etc. Hopefully the whine wont get much louder once the smaller pulley is put on.
Although it didnt look much the inlet itself took around 12-14+hrs to build. Yours sounded pretty lairy too lovely noise to be following. :)
Good day, was a nice run back over the somerset levels :) shame we hit some slow moving traffic.
stef205
Not much has happened on this over the last few weeks due to another peugeot that has come into my life, we bought this the other day for my missus
needs abit of work but soild shell.
One the 205 front ive yet to send the charger off :( i really must pull my finger out. suddenly the charger has woken up abit more and i am now on a whole 4psi!
stef205
Awhile since a update, been currently been suffering with bad front brakes, constant wrapping etc, despite new pad, discs, new slides to find the caliper housing and pistons are worn. I have been debating on some 4 pots so i decided to take the plunge on these.
These worked out much cheaper than the 406 option, admittedly they may weigh more but im not weight obsessed.
After a quick chat with mickie he sent me over his desgin for the brackets to fit them but turned out they were for 1600 hubs.
I need to go to dans to pinch a hub from him so i am able to mock these up.
All for now :)
stef205
I did abit more on the calipers this afternoon, started to get them mounted to some old hubs.
Got a issue with the bracket as one of the holes doesn't line up with the hub
I'll be off to the machine shop on Monday for some new ones.
dcc
upside down? :P
What car are they off?
stef205
Skyline r33 gts, the do have left and right marked on them.
Edited by stef205
stef205
bit of an update on these calipers, calipers had to go on mill to gain more pad to disc coverage.
This morning i got them bolted up to the car for the first time.
As with the 406 brembos i knew the wheel would never fit, Im thinking about some new wheels but im not very good with wheel offsets etc id like a set of the sl434's but unsure if they are better or worse for offset. Iknow they are et8 and my cyclones are et19 again this means nothing to me.
It means the centreline is 11mm further out, though in reality the inner edge isn't much further due to the additional width.
here's a very useful web page where you can compare wheel sizing www.willtheyfit.com ( I have added the original 1.9 and the SL434's dimensions with the standard 1.9 tyre as a comparison)
whether this will have a direct affect depends on the design of the wheels, for example a 1.9 wheel needs a fair spacer to clear a brembo caliper, not due to their diameter, but their bulk at the inner diameter of the hub section of the wheel, AND the curve of the spokes as they meet the rim.
stef205
ok thanks mei, yeah the diameter of it all is fine its where the wheel spokes meet the out side of the caliper.
damo
glad to see the 205 still on the road :) nice to catch up Sunday mate. good luck with the brakes.
stef205
Yes it was mate, I've got the brakes bolted up to your hubs atm with some 307 discs, just to find some time to see if the wheels fit. Will be nice to have some brakes that don't shake.
stef205
Bit of update hasn't been a good week for the car. I had recently been hearing some kind of noises but wasn't able to pin point where from. Last Saturday night I left work and pulled away and heard a almighty bang! Car wouldn't move or even roll. So it was recovered to the workshop by the rac, watching the car been dragged up the lorry bed I knew it wasn't good. Next day I went to the workshop to find this
Whoops!
On a better side damo was nice enough to lend me his spare set of hubs so I could mock the skyline calipers up on. With the brackets finished off I've only to work out what size spacers ill need.
New gearbox should be going in tomorrow that I got from dan and turned out to be a nice 1.9 box, had to change the outer case but came together nicely, fresh clutch and we should be away again :D
stef205
small update,
1.9 box is in with a new luk clutch, lovely and smooth, compared to the old worn 1.6 box.
calipers update had them shot blasted recently and stripped and cleaned
AB418245-9437-48EA-8753-0E82848C179A-757
Then sprayed them with etch primer and some red and hand painted the nissan with with, not everyones taste but matches the rear.
0017F0C0-85C6-463F-A18A-415D8E494D44-129
cheesegrater
Cars looking good. Did you ever change your pulley over to the 54mm one? What kind of pressure are you getting now?
stef205
No I haven't yet, still on 5psi yet to have the cam timing checked. Mainly know one wants to take the job on. I think once I've got a wideband in I will change the pulley.
stef205
Today I had some new wheels fitted at topgear in bridport, also mainly to clear my brakes I have to go on, they are 15" 7j et15 loads more clearance than what I was getting with cyclones. £430 later
729F8AAD-452D-488C-B02F-543821FD5FF6-264
Is that with a 309 beam on the back? If so, I don't fancy your chances with the arches surviving long!
Does look good though with the wide stance and slightly agressive look of the intercooler and bonnet bulge :D
I must be the only one that dislikes that look of wheels outside the arches :lol:
stef205
Yes it's is a 309 beam it's hasn't scrubbed yet, ha! The arches have been shaved over the last year. Can't please every one I spose! :D
chipstick
Extreme measures to fit some brakes :D
Best get the use out of them on track this year eh?
stef205
Possibly dan you have been talking me into it lately and have been practicing with the 205 on forza too haha
